    • singer 재봉틀 비교
      • 2016.12.06 - 20:56 2016.11.26 - 08:33 6078 8
    출처 : http://www.sewinginsight.com/a-comparison-of-singer-heavy-duty-sewing-machines/
    What Sets Them Apart
    MODEL # # OF
    STITCHES
    STITCHES
    PER
    MINUTE
    ADDITIONAL
    FEATURES
    ADDITIONAL
    ACCESSORIES
    WHERE TO BUY MSRP
    44S Classic 23 1100 Automatic needle threader None walmart.com exclusively <$150
    4411 11 1100 None None Independent authorized dealers*;
    internet
    <$200
    4423 23 1100 Automatic needle threader None Big box stores;
    internet
    <$200
    4432 32 1100
    Automatic needle threader;
    automatic 1-step buttonhole
    Quick start guide Internet <$400
    4443 I** 23 1100 Automatic needle threader;
    automatic 1- step buttonhole
    Even feed/ walking foot;
    non-stick foot;
    clearance plate;
    heavy duty needles – size 16
    Independent authorized dealers <$400
    4452** 32 1100 Automatic needle threader;
    non-stick foot;
    clearance plate;
    Independent authorized dealers <$500
    5532 32 1100 Automatic needle threader;
    Quick start guide Independent authorized dealers;
    internet
    <$500
    S161
    Studio**
    Straight
    stitch
    only
    1600 Automatic needle threader;
    Vertical side loading bobbin;
    extra large work space (9 x 6);
    independent bobbin winding;
    programmable needle up/down;
    ¼” foot; free motion foot;
    narrow rolled hem foot;
    darning plate;
    thread spool cap;
    thread spool net;
    thread spool holder;
    2 screwdrivers;
    fabric guide and setscrew;
    accessory storage case;
    oil dispenser;
    knee lifter;
    quick start guide
    Independent authorized dealers; internet >$500
    CG 590
    Commercial
    18 1100 Drop feed;
    adjustable speed control
    Blind stitch presser foot;
    finger guard
    Big box stores;
    internet
    <$300
    Singer I
    Professional***
    6 1250 Heavy duty interior metal frame;
    extra large metal work space;
    Straight stitch presser foot & needle plate;
    blind hem foot;
    satin stitch foot ;
    darning plate;
    spool caps;
    finger guard;
    seam guide;
    quick start guide
    Independent authorized dealers >$500
    * It appears as though this machine, while currently available through independent authorized dealers, is being shifted to the internet market
    ** Released in 2014
    *** Coming soon [fall 2014]
    ban 설정 강화 12906 1 2026 05.09 정적분 구간에 미지수가 있고, solve 를 사용할 수 없을 때 그 값을 확인하려면? 2194 4 2026 04.10 높아질수록 좁아지는 시야에 대하여 - written by ChatGPT 9194 2026 02.12 내가 올해 몇살이더라? (내 나이 계산기) 7733 2026 02.11 AGI 자기 거버넌스 구조와 인간-AGI 관계 모델 (written by GEMINI & GPT) 9469 1 2026 01.30
    - claude AI는 l-c*r^2 을 1-c*r^2 으로 잘못 읽고 표시하고 있습니다. - TI-nspire CAS 계산기에 l-c*r^2 ≥0 을 조건에 추가해 계산해 보아도 결과는 바뀌지 않습니다. 2026 07.20 ⚠️ 경고가 바로 두 번째 방법이 "성공"한 이유와 정확히 연결되어 있습니다.   경고의 의미 "Domain of the result might be larger than the domain of the input"는 CAS가 절댓값(모듈러스)을 계산하는 과정에서 원래 식보다 정의역이 더 넓은 형태로 단순화했다는 뜻입니다. 구체적으로 이 계산은 내부적으로 대략 이런 과정을 거칩니다. $$\left|\frac{er}{e\cdot r}\right| = \sqrt{\left(\frac{er}{e\cdot r}\right)\cdot\overline{\left(\frac{er}{e\cdot r}\right)}}$$ 즉 원래 식(복소수)과 그 켤레복소수를 곱해서 실수부·허수부 제곱합을 만들고, 거기에 다시 제곱근을 씌우는 과정입니다. 이 과정에서 √(x²) → x 또는 √a·√b → √(ab) 같은 규칙들이 쓰이는데, 이런 규칙들은 x가 실수이고 0 이상일 때만 엄밀하게 성립합니다. CAS는 이 조건들을 일일이 다 추적하지 않고 넘어가면서, 원래는 (e≠0, r+l·ω·i ≠ 0 등) 복소수 특유의 좁은 정의역을 가진 식을, r, l, ω가 어떤 실수여도(부호 무관하게) 정의되는 1/√(r²+l²·ω²)라는 더 넓은 정의역의 식으로 바꿔버린 것입니다. CAS는 이 손실을 감지하고 경고를 띄운 것입니다. 이게 왜 조건 대입 성공과 연결되는가 정리하면, 이 경고는 사실상 이런 뜻입니다. "나는 이 결과를 만들면서 원래 식이 가지고 있던 정의역 제약 정보(부호 조건, i 관련 조건 등)를 이미 버렸다." 바로 이 "정의역 정보를 버린" 상태가 이후 con_1 대입을 매끄럽게 만드는 원인입니다. 첫 번째 시도에서는 i가 살아있는 원래 식에 조건을 대입했기 때문에, CAS가 √(1-c·r²)이 실수인지(정의역 조건: 1-c·r² ≥ 0) 계속 추적하려고 했고, 그 정보가 con에 없어서 더 이상 정리를 못 하고 멈췄습니다. 두 번째 시도에서는 절댓값 계산 단계에서 이미 그런 세밀한 정의역 추적을 CAS 스스로 포기(단순화)했기 때문에, 이후 ω에 무리식을 대입해도 "이게 실수가 맞나?" 하는 검증 절차 없이 그냥 대수적으로 치환·정리해 버립니다. 그래서 깔끔하게 √c/√l이 나온 겁니다. 한 줄 요약 절댓값 계산 시 뜬 "정의역이 넓어졌을 수 있다"는 경고는, CAS가 그 순간에 원래 식의 엄밀한 조건(정의역)을 놓쳤다는 신호이고, 바로 그 "조건을 놓친 상태"이기 때문에 뒤에 이어지는 조건식 대입이 막힘없이 진행된 것입니다. 다만 그 대가로, 결과인 1/√(r²+l²·ω²)이나 최종 √c/√l이 원래 회로 조건(i≠0이 되는 경계, 분모가 0이 되는 경우 등)에서는 엄밀히 성립하지 않을 수 있다는 점은 감안하셔야 합니다. 실제 물리적으로는 r, l, c > 0이고 결과도 물리적으로 타당한 형태라 문제없어 보이지만, 수학적 엄밀성 측면에서는 "정의역이 넓어진 근사적 결과"라는 꼬리표가 붙어있는 셈입니다. 2026 07.20 Claude AI 답변 TI-Nspire CAS의 | (such that / 조건대입) 연산자는 대입 시점의 수식 형태를 그대로 두고 기호만 치환하는 연산입니다. 대입 후에 처음부터 다시 "실수부/허수부 분리, 유리화" 같은 재간소화를 자동으로 수행하지 않습니다. 이 차이가 지금 보신 결과 차이의 핵심입니다. 첫 번째 경우 (|er/(e·r)| | con_1 and con → 실패) 이 시점의 식은 아직 r + l·ω·i 형태의 복소수 그대로입니다 (i가 살아있음). 여기에 con_1: ω = √(1-c·r²)/(√c·l)을 대입하면, 분모 안에 i · √(1-c·r²) 라는 항이 새로 생깁니다. 문제는 CAS가 √(1-c·r²)이 실수인지(즉 1-c·r² ≥ 0인지) 판단할 근거가 없다는 겁니다. 저장해 두신 con 조건은 c>0, l>0, r>0뿐이고, 1-c·r²≥0이라는 조건은 포함되어 있지 않습니다. 그래서 CAS는 i와 이 무리식을 더 정리(유리화, 실수부·허수부 재결합)하지 못하고 있는 그대로 남겨둡니다. 결과에 여전히 i가 보이는 이유입니다. 두 번째 경우 (결과값 1/√(r²+l²·ω²)에 대입 → 성공) |er/(e·r)| (절댓값/모듈러스) 연산은 그 자체로 이미 "복소수 → 실수" 변환을 완료한 결과입니다. 즉 1/√(r²+l²·ω²)에는 더 이상 i가 없고, 순수하게 r, l, ω로만 이루어진 실수식입니다. 이 식에 ω = con_1을 대입하는 것은 그냥 실수 대수식에 실수 대입하는 것이므로, i와 무리식이 뒤엉키는 문제 자체가 발생하지 않습니다. 그래서 바로 깔끔하게 √c/√l로 정리됩니다. 정리하면 절댓값(모듈러스) 계산은 "이 값들이 실수다"라는 가정을 이미 내부적으로 써서 i를 제거하는 연산입니다. 그 연산을 조건 대입 이전에 해두면, 이후 대입은 단순 실수 대입이라 문제없이 정리됩니다. 반대로 i가 남아있는 식에 무리식을 포함한 조건을 먼저 대입하면, 그 무리식의 실수성/부호에 대한 가정이 없어서 CAS가 i를 소거하는 재간소화를 못 하고 멈춰버립니다. 실용적 팁: 복소식에 조건을 대입해야 할 때는 가능하면 절댓값·실수화(유리화) 등을 먼저 끝내서 i를 없앤 뒤 조건을 대입하거나, 대입 후 결과에 다시 simplify/expand/combine 같은 명령을 한 번 더 걸어주면 (필요한 도메인 조건과 함께) 정리가 되는 경우가 많습니다. 2026 07.19 저도 어림잡아 추측할 뿐이지 정확한 이유를 알지는 못합니다.    질문하신 사진을 그대로 (Gemini 3.5 Flash / ChatGPT / Claude Sonnet 5) AI에 넣어 보니  claude AI 가 제일 합리적인 답변을 주어서 이를 붙여 넣습니다.  2026 07.19 아 그렇네요. 감사합니다. ^^ 2026 04.28
      2016.11.26 - 13:22 2016.11.26 - 10:13 #19132
      Automatic needle threader : 자동 실 꿰기
      2016.11.26 - 10:28 2016.11.26 - 10:25 #19135
      automatic 1-step buttonhole : 자동 단추 구멍 만들기
      2016.11.26 - 10:25 #19138
       Vertical side loading bobbin : 수직 가마 ?
      2016.11.27 - 15:40 2016.11.26 - 10:27 #19141
      Even feed/ walking foot : 천을 손으로 밀지 않아도 자동으로 조금씩 들어가는 노루 발
      2016.11.26 - 13:13 #19144
      blind hem foot : 속상침? 숨겨박기? 둘 중 하나인 것 같은데 모르겠습니다.
      2016.11.26 - 13:17 #19147
      non-stick foot :  가죽, 플라스틱, 비닐, 기름천? 같은 것을 박을 때 쓰는 노루발
      2016.12.05 - 18:51 2016.12.05 - 18:46 #19262
      6199-brilliance
      http://www.singerco.com/products/2181/6199-brilliance
      • 100 Built-In Stitches
        The right stitch: easier sewing with better results. Includes: 9 Basic, 76 Decorative, 8 Stretch and 7 Buttonholes
      • Automatic Needle Threader
        Threading the needle is quick and easy.
      • 6 Fully Automatic 1-Step Buttonholes
        Buttonhole sewing is a one-step simple process, providing reliable results every time. Each side of the buttonhole is sewn in the same direction creating beautifully balanced buttonholes.
      • 1 Endless Buttonhole
        There are no size limitations with this buttonhole. Ideal for sewing nontraditional sized button holes.
      • Push Button Stitch Selection
        Easily select your desired stitch with a push of a button.
      • Automatic Stitch Width & Length
        The right stitch setting every time. Automatic settings for width and length may be overridden to personalize stitch size.
      • Up to 6.5 mm Stitch Width
        Many stitches can be set for a maximum width of 6.5 mm creating attractive satin and decorative stitches.
      • Automatic Tension
        Automatically keeps stitches balanced and even.
      • Heavy Duty Metal Frame
        This rigid support holds all the mechanisms in perfect alignment for precise sewing and durability.
      • Hard-Sided Cover
        Carry your machine safely and keep dust-free in storage.
      • Extension Table
        Manage large projects easily with more sewing surface.
      • Automatic Presser Foot Pressure
        Easily sew the lightest weight tricots to the heaviest denim without the need for presser foot pressure adjustments.
      • Extra-High Presser Foot Lifter
        Offers more clearance, which is needed when placing multiple layers of bulky fabric under the presser foot
      • 13 Needle Positions
        Needle position can be changed for individual projects, such as inserting zippers or cording and topstitching.
      • Automatic Reverse
        Push the conveniently located Automatic Reverse Button to sew in reverse and reinforce the stitch.
      • Sewing Speed
        With a maximum sewing speed of 750 stitches-per-minute, projects can be sewn quickly.
      • Free Arm
        Provides easy access to cuffs, collars, pant hems and other smaller or difficult-to-reach areas
      • 8 Snap-on Presser Feet
        Expands your creative sewing possibilities. Quick release for easy on and off!
      • Included Accessories
        All-Purpose Foot, Zipper Foot, Buttonhole Foot, Blind Hem Foot, Button Sewing Foot, Overcasting Foot, Invisible Zipper Foot, Shank, Roller Foot, Pack of Needles, Bobbins, Thread Spool Caps, Auxiliary Spool Pin, Spool Pin Felt, Darning Plate, Needle Plate Screwdriver, Seam Ripper / Lint Brush, Extension Table and Hard-Sided Dust Cover.
      • On Board Storage
        The accessories are conveniently stored in the removable storage compartment providing easy access.
      2016.12.06 - 20:56 #19280
      http://www.singerkorea.co.kr/comparechart/compare01-multi.html
      미싱기능 비교표 (한글)
